  1. I have a Mp4 file. Which is the first time I have ever seen one. What do I need to convert it to AVI file?? Or can I burn is streight to disk and play it in my DVD player.
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    An MP4 is a TRUE MPEG-4--not a Divx, Xvid or Microsoft MPEG-4
    It is the kind of MPEG-4 made by APPLE QUICKTIME
    The only way to decode to another format
    requires QUICKTIME PRO
    only available at apples website for SIXTY dollars (including MPEG-2)
    or 40 dollars without MPEG-2
    When you get it..Go to the file menu and choose EXPORT>I don't think you can export to MPEG-2 directly unfortunately> so go to QUICK TIME and choose UNCOMPRESSED or a CODEC you like to use that doesn't compress too much
    You didn't say If you had access to a MAC.. Here you would open final cut pro (hope it accepts MP4) and re render to MPEG pairs (A+V seperate for authoring)
