Hi,
Got a film, 3 mpgs. Process looked to work. Played the vobs and it seems for the length of the first mpg, the sound is about 2 seconds out. Once the film gets to the same time as the second mpg begins then all is fine.
Any suggestions?
To all those past and present. All those that have fought for our freedoms. God Bless. Those of you that are fighting now,
keep your heads low. Those of you back home hold your heads high. -
try this:
1. open tmpgenc load the origional mpeg of the one with the sync probs.
2. select the template you need vcd, svcd, dvd, pal or ntsc
3. load the unlock template
4. select only ES audiostream
5. let tmpegenc create the audiostream
6. op tmpgenc author load the files svcd2dvdmpg create and the audio file of step 5.
7. create a dvd
8. done
it works for me
Yf
VOB to mgp lossless
By casperinmd in forum SVCD2DVD & VOB2MPGReplies: 17Last Post: 2nd May 2009, 11:37 -
Help with 1st up of Kiss DP-1600
By GJLCAP in forum Media Center PC / MediaCentersReplies: 1Last Post: 4th Aug 2008, 14:52 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 14:33 -
my 1st dvd recorder
By M-girl in forum DVD & Blu-ray RecordersReplies: 20Last Post: 11th May 2007, 00:15
