I've noticed an annoying problem with Ulead Movie Factory 2 I just can't seem to get around.
If I have one clip I want to create multiple chapters with, I seem to be getting two menu screens.
What I mean is I get one with the name of the clip and then a second with all the chapter points.
I can see the benefit of this - if I upload say four clips and want multiple chapter points from each then it would be a wonderful facility, but I only want one menu showing the chapter points I've created.
I appreciate if I split the initial clip into multiple files and upload those I don't need to create chapters and therefore but not checking the chapters box I only get one menu screen, but on the clip I have I dont want to split it, theres too many chapters.
Is there a way to upload one clip, create multiple chapter points and only be presented with one menu screen?
Thanks,
Will
Results 1 to 9 of 9
tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
I'm glad I'm not the only one who finds this annoying. I have MovieFactory and VideoStudio and both can't seem to create just the chapter menu without the main menu. I wonder if Ulead's other authoring app, DVD Workshop, can do the job? Hmm...
I'll have to email Ulead's Tech Support and see if I can find out if this is possible with any of the mentioned apps. -
DVD Workshop definitely can do it. It has a much greater range of customization. MF2 is your basic "Click 'n Burn"
Originally Posted by Supreme2k
I wanted something simple and Ulead MF, prior to this little distraction, was ideal.
Originally Posted by Gil T Pleasure
It's fine they've added it because as I mentioned it has it's uses but a damn annoyance you don't have the option to remove it.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Silky31,
You're right. MF does not create main menu + chapter menu if you only have one video. I didn't realize that before, thanks for the pointer. It's actually VideoStudio7 that did that. But now I can just import all of my 1-video projects (created in VS7) to MF if I want to avoid this annoyance.
Thanks again! -
The strange thing is I imported the same clip into MF1 last night and each time I tried to create chapter points it froze.
Did it three times.
I've heard it's a little complex.
I don't want to rush and buy it if I'm going to struggle with it.
Damn! I just found out I can't import VS7 projects into MF and MF doesn't have an Auto Add Chapter option (for those times when I'm feeling lazy and would rather have the software pick the chapter marks for me). Does MF2 have this option?
yes, it has autochaptering, you st it by time duration, eg 3mins/ 15mins etc etc
The only difference between right and wrong is gender........
Ulead DVD Movie Factory 6 Plus
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Play chapter then return to title in Movie factory
By jlctom in forum Authoring (DVD)Replies: 0Last Post: 1st Jan 2009, 16:47 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 02:20 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
