I been trying to convert some of my old SVCD's to DVD since I own a DVD+RW burner now. The problem comes when I try to convert a 3 CD movie-set. Everything seems to go just fine, only when SVCD2DVDMPG starts working on the 2nd part, my PC crashes and resets.
I checked HDD's and memory, thats all fine. What can this be???
Ronin2k3Guest
Never seen this before. Is it just that 2nd CD? As a test have tried just doing the 2nd CD on its own? At what stage does this happen? What OS you running?
Ronin2k3Guest
I am using Windows XP as OS, just been checking some more and it seems that my Creative Audigy 1394 is doing this. The PC crashed while converting the audio stream. After that, the PC also crashed while watching a WMV video file. I could hear the sound go all crackling and soon after (5 secs) my PC rebooted again.
The files are now converted by the way, using my PC @ work. I will reinstall Windows XP and Sound drivers and see what that does. -
Cyberex: No. Try another forum here on DVDRHELP. This one is just SVCD2DVD/MPG
Um, now what? I'm stuck - SVCD2DVDMPG usage
By Hal05154 in forum Video ConversionReplies: 4Last Post: 13th Aug 2007, 08:59 -
Monitor / Display Resets - Dying Graphics Card?
By daamon in forum ComputerReplies: 15Last Post: 17th Jun 2007, 03:41
