  1. I'm trying to load a divx file of macross zero episode 1 (for those of you who know what it is) in vdub but when I try to play it or framserve it to tmpgenc it says file not supported. I loaded it into avicodec and it says its a divx file but under gspot it says its an xvid file and media player 9 is saying its a panasonic dv file. I don't know if I'm doing something wrong or if the file is just whacked but if someone can enlighten me that would be great. Thanks in advance.
    Mel
    Apr 2002
    The State of Frustration
    Have all your codecs loaded?
    Hello.
  3. Yes all codecs are loaded.
    Apr 2002
    And Direct Show priority set as the highest?
    Hello.
