I copied a home video on my HS2 and copied it to my PC. I have MSP 7 with Moviefactory 2LE. MSP7 seems to be a great program but when it was time to render the project it saved seperate MPEG files for each clip which is fine but created seperate audio and video files. when I try to import these files into Moviefactory 2LE, it will only accept the video files. so the end result is video with no sound. I tried playing the files on Win DVD and would only play the video.
Moviefactory 2 would play Audio and video just fine when the original 1 file copy was imported into it. Is this common for seperate audio video files when rendering Or did something go wrong? I know some will tell me to use a muxxing program but I feel I shouldn't have to do that.
Also if interested MSP7 academic upgrade is $122 and MSP 5 is $30 on EBAY.
I solved the problem by clicking on CREATE / VIDEO FILE and so on put every thing back together again.
But the Audio format selector is greyed out and can't choose the AC3 option.
I want to transform my PSF MTS camcorder video without reencoding the video
By Stears555 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 8th Feb 2012, 05:52 -
Audio-only reencoding?
By woecarlson in forum Blu-ray RippingReplies: 0Last Post: 11th Apr 2011, 14:30 -
mux m2ts to m2ts with AC3 audio without reencoding the video
By BirdDaddie in forum Video ConversionReplies: 3Last Post: 22nd Aug 2010, 21:19 -
video splits half way through
By Redbeard in forum Software PlayingReplies: 2Last Post: 9th Jul 2008, 13:19 -
What's that thing called that splits an s-video/RCA(Composite)?
By RoganSarine in forum Capturing and VCRReplies: 10Last Post: 31st Dec 2007, 04:06
