Results 1 to 13 of 13
  1. OK. sorry if this an old one, but I really have searched the forums for the answer.
    I've been making VCD's for over a year ( using the guides on here ) without any problem. I use TMPGEnc to encode but since buying a new PC and swithching to XP Home Edition I carn't do a damn thing . Every film crashes whilst encoding... I have everything set as before but can not get a film to finish encoding.
    Any suggestions would be welcome as I'm now desperate.
    Beery
  2. XP doesn't come with the proper ASPI drivers.
    Try searching for ForceASPI and install that.
    That should correct your problem
  3. I got my ASPI but just installing NERO
    "Today is only yesterdays tomorrow"
  4. Thanks guys, I'll see if that works. I must have encoded over 200 movies on my last PC but now all I get is error after error. If anybody else has any suggestions please let me know as desperation is setting in.
    As for the exact error .... well ??? Tmpgenc just stops encoding after a few minutes, I get no error message just the XP one saying the Program has stopped responding.
    Beery
    ontario ,canada
    I installed adaptec aspi drivers and it works ok.
    bmiller,ont.canada
  6. I had the same problem when I first started and it was the am drivers. Bash them in and you will be sorted.
    If it's wet, drink it
    My DVD Collection
  7. Originally Posted by hardcoreruss
    Forgive my lameness but could you give me a bit more help here.... sorry but I'm a little thick
    Beery
  8. When you open VCDEasy , on the right does it give you a menu of ASPI (ie:I have Nero and Adaptec)?
  9. Originally Posted by wee haggis
    Yes it say's exactly that....
    I tried to encode again, most files get to 13% and then TMPGEnc just stops responding...
    Beery
  10. some of the old version of TMPG do not work in XP TMPG fixed this problem about a month after XP came out
  11. Well would you believe it ... I've got the damn thing to work. I done most of what was suggested and also found an old Copy of TMPGEnc I had on my old PC. I set everything up as suggested in the guides and HEY PRESTO it worked....so fingers crossed thats it...
    Thanks to all those who have helped me, and please keep the suggestions comming in.... as it could all fail once again.
    With thanks
    Beery
  12. I've had the same crashing problem with tmpeg but it was the software problem, not XP. The newest version crashed each and every time. And I thought that something was wrong with my computer. But I later found out that my previous version worked perfectly without any problem. So I reinstalled the previous version and works fine.
  13. Originally Posted by pskim
    There is a newer version than the constant crashing 2.511. 2.512 just came out and is pretty stable. Either reinstall 2.510 or upgrade to 2.512, discard any versions of 2.511 as that will kill you every time.
    Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
