I downloaded an AVI video file and the audio is out of sync with the video. Is there a way to correct this, or because it was downloaded was it possibly a bad file to begin with.
Open the avi file in virtualdub. Click video - direct stream copy.
Click audio - full processing mode.
Click audio again and interleaving.
Change the startup delays of your audio track.
When your finished, click file - save avi"Today is only yesterdays tomorrow" -
Thanks for your help, but there must be something else wrong, as when I tell it to save I get message No audio decompressor could be found. Any additional suggestions.
Thanks -
You may have a codec problem. Get Gspot form the Tools section and test your file. It will tell you if you have the required audio codec on your system, if not, then you will need to get it.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
MKVvextract stretches extracted audio/Audio not in sync with video
By cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 17:15 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
Audio and video out of sync
By mangrum6160 in forum Video ConversionReplies: 1Last Post: 13th May 2010, 23:08 -
audio and video out of sync
By lbbruiser1 in forum AudioReplies: 1Last Post: 2nd Dec 2007, 11:14
