Hello,
I have done some looking around and have not seen anything that address my problem (which means I probably missed it). I have messing around with some home video that I saved as SVCD. After I start the process the various dos windows pop up. It then gets to one called C:\Program Files\SVCD2DVDMPG+\mplex.exe and the process stops. The svcd2dvdmpg+ log is listed below, as is the output of the dos window. the only problem I can see is the line that says INFO: [mplex] Selecting DVD output profile (INCOMEPLETE!!!!). Can someone help me out with this. As I have said I have checked here and at the author's website but have not come up with anything.
Thanks,
Henry
############### New MPEG File ###############
File: D:\test\Disk1.MPG
Horizontal Res: 480
Audio SampleRate: 44100
******** Demultipexing original mpg file
******** Resampling audio from 44.1 KHz to 48 KHz
******** Multipexing elementry streams
Dos window titled C:\Program Files\SVCD2DVDMPG+\mplex.exe output
INFO: [mplex] mplex version 2.2.1 ($Date: 2002/02/04 19:06:14 $)
INFO: [mplex] File D:\test\Disk1_DVD.mpv looks like an MPEG Video stream.
INFO: [mplex] File D:\test\Disk1_DVD.mpa looks like an MPEG Audio stream.
INFO: [mplex] Found 1 video streams 1 MPEG audio streams and 0 AC3 streams
INFO: [mplex] Scanning for header info: Video stream e0 (D:\test\Disk1_DVD.mpv)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 480
INFO: [mplex] Frame height : 576
INFO: [mplex] Aspect ratio : 4:3 display
INFO: [mplex] Picture rate : 25.000 frames/sec
INFO: [mplex] Bit rate : 2500000 bits/sec
INFO: [mplex] Vbv buffer size : 114688 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (D:\test\Disk1_DVD.mpa)
INFO: [mplex] AUDIO STREAM:
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 3
INFO: [mplex] CRC checksums : yes
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 2780000
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Sectors = 89 Video delay = 13019 Audio delay = 13019
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
Fonze73: this is a issue which has come up before. It is due to the fact that you need BeSweet 1.5b17+ as instucted in your "Welcome" email.
Thank you for your reply.
Per the welcome message I went to the listed website and downloaded the latest beta, BeSweet1.5b18 and installed it. Is there someplace I can get BeSweet1.5b17 from or is there something else I missed?
Thanks,
Henry -
Well if you have 1.5b18 you should be ok. Maybe something in the mpeg structure which is amiss. (that INCOMPLETE msg is just what you get when multiplexing for DVD content)
How about this. when you get to this stage - kill SVCD2DVDMPG. Then kill the dos box. Then type:
"c:\program files\badgersoft\svcd2dvdmpg+\mplex.exe" -v 2 –f 8 –o out.mpg videopart.mpv audiopart.mpa
from a command window after cd-ing to your working directory. Substitute filenames accordingly (choose the mpg streams which are causing issue). This will give a more detailsed output.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for your recommendation. I tired it from the dos prompt and the process completed succesfully (go figure). Since that work I tried svcd2dvdmpg+ again and got the same message in the dos window. This time I went ahead and let the program run and kept refreshing the file window which showed the file size of the resulting .mpg increasing. Eventually the dos window with the "error" disappeared and the dvd directories was made.
I don't know what it means. Thanks for the quick response and suggestions.
Henry
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 10:31 -
Video (movie) Stoppage
By jackowens in forum Newbie / General discussionsReplies: 0Last Post: 29th Sep 2009, 17:55 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 09:42 -
bgsvcgen.exe?
By alegator in forum ComputerReplies: 11Last Post: 16th Jul 2007, 13:06 -
.exe to .avi
By siopawman in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 21:46
