  1. Member LisaB's Avatar
    I have a movie which was divided into one-minute clips. Unfortunately, there is slight overlap with the end of one clip and the beginning of the next. So, when joining with TMPGEnc MPEG-Tools, I get a movie with little repeats every minute!
    Is ther any joining tool out there which is smart enough to recognize overlap and do a seamless join?
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    I don't know of one.
    but in TMPGenc, when you add your clips to the list to be joined, if you click on the file name, you can set a range for your start and your end, so you could trim it yourself at the right points.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
