I'll give it a whirl - thanks.![]()
Results 31 to 34 of 34
please also remember that chapters must not only be created on a I frame but must be also at the beginning of a GOP , so usually every 12-18 frames ...
Originally Posted by F-ING HOSTILE
I don't know what to try anymore.
I thought I had the problem licked.I used IFOUpdate to get my I-Frame points (CCE film setting) and added them to my ecl text before encoding. Then I used IFOUpdate to save my chapter points (Maestro File CHP) to import into my project in Maestro. I tested two movies ("American History X" and "Men Of Honor") My chapter points were still off by a second or so. Then, when I changed the "Chapter point properties" in Maestro from "Timecode (T.C.) based" "Next GOP" to "Timecode based" "Nearest GOP", and reimported my chapter file, I watched as my points landed exactly where they were in the original! The problem came when I tested a third movie ("Top Gun"). With these new settings, several of the chapter points were 1 second or less early (just early enough that the Chapter picture screen had not passed over to the next scene). Now when I switched from "Timecode based" to "index based", and went back to "Next GOP", everything seemed fine (with Top Gun). When I tried "American History X" again, the points were a second or so late! WTF? I guess I will just stick with the "Timecode based""Nearest GOP" settings and deal with it!
I don't know what else to try.
This problem has only really popped up since I switched from TMPGEnc to CCE. I would guess it has something to do with the fact that TMPGEnc automatically performs it's own 3:2 pulldown. I have been using "Pulldown.exe" for the mpv's that CCE gives me, and wonder if maybe this would have anything to do with the inconsistency I have been experiencing in chapter points. Someone (Adam) mentioned,” Make sure you set Maestro to drop frame though, as this could also make your chapters off", but I can't find any settings in Maestro that deal with "Drop Frame" In a similar post about Maestro, and chapter points, "Disturbed 1" wrote,” Use the -drop_frame true flag in pulldown (if your using NTSC film as a source) to correct the time code", but I'm guessing this is performed automatically by "Pulldown.exe". Someone also said to "enable pulldown" in CCE, but I could not find anything in CCE dealing with that.
I'm really frustrated with it by now, and have run out of ideas. I suppose having the points be a fraction of a second early is as close as I will get! I'll just have to drag them a second forward into their proper scene
IFOEDIT edit chapter points?
By wulf109 in forum DVD RippingReplies: 4Last Post: 29th Oct 2011, 20:42 -
User-defined chapter points
By saber540ltd in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 26th Mar 2008, 18:38 -
DVD chapter points
By Supreme2k in forum Off topicReplies: 3Last Post: 26th Oct 2007, 10:39 -
new chapter points in PGCedit
By kshavo in forum Authoring (DVD)Replies: 5Last Post: 10th Jul 2007, 13:51 -
Moving Chapter Points?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jun 2007, 20:33
