I've used both ULead DVD Workshop and TMPGEnc, with the same result. My downloaded AVI file always has out of sync audio.
I'm a newbie to DVD authoring, but it looks like something is wrong with my AVI. I used VirtualDub MP3 to check for frame problems, and it found none.
I am currently using extracting the wav file out separately and will try to combine them when I author the DVD. I have no idea if that will make a difference!
Any ideas what might be going on?
Thanks,
Brian
Check out this thread: https://www.videohelp.com/forum/viewtopic.php?t=161675
and also this one: https://www.videohelp.com/forum/viewtopic.php?t=160649
The second one helps get the audio right and the first one looks like a nice way to get the two in sync. Let me know how it works.
Goodluck,
VCThis is so much fun!
Audio/video out of sync after converting (avi to mp4)
By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 12:13 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 11:23 -
audio video avi file out of sync when converting with nero
By paulthewall37 in forum AudioReplies: 2Last Post: 28th Feb 2010, 18:06 -
Audio & Video In Sync
By marioval in forum Authoring (DVD)Replies: 22Last Post: 22nd Oct 2007, 18:13 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 23:22
