Hi!
I've a question regarding the "Enable Padding" setting in TMPGEnc. I've encoded a part of a DVD movie in VBR (1150 min, 1800 max, 1455 average) without checking the box "Enable Padding". I chose a 1455 average bitrate to completely fit an 80 min CD but it turned out that the resulting file had a size significantly smaller than the expected.
I did another try with the same settings but this time checking the box "Enable Padding", getting a file with the "right" size, according to the average bitrate.
However I'm not sure that this increase in the filesize, due to the padding, goes on with an increase in video quality.
If this were not the case, I guess that I could increase the average bitrate above the theoretically bitrate needed to fit a CD, to obtain a file with a greater size to "really" fit a full CD and getting also a real increase in video quality.
Am I right or is this strategy useless?
In any case, the MPEG file I got without the "Enable Padding" option enable and a reduced filesize could be burnt to a CDRW with VCDEasy and played in my stand-alone player without any problems, except for the count time that was wrong (something I don't really care too much).
Thanks in advance
Giskard
Results 1 to 1 of 1
Problem padding with ffmpeg
By joesphroth in forum Video ConversionReplies: 8Last Post: 6th Dec 2011, 17:56 -
padding question for coversion to smartphone
By RdM642 in forum Video ConversionReplies: 0Last Post: 8th Sep 2010, 05:03 -
Add padding to videos
By marioval in forum Newbie / General discussionsReplies: 6Last Post: 7th Dec 2009, 06:22 -
Padding in DVD Author 3
By pepegot1 in forum Authoring (DVD)Replies: 6Last Post: 16th May 2009, 15:21 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 09:17
