mY burner used to work fine but now it fails on me every time around 70-90% of the completion of the disk. I reinstalled win xp and it still didnt work. So i installed win 2k pro and it still does not work. I updated my motherboard drivers already but it is still not working. Could it have something to do with what IDE it is pluged into cause i might have changed that i cant remember. Any help would be very appreciated.
have you installed any of the new firmware? i just did mine as written down elsewhere on the forums and it has really opened mine up. Faster ripping, region free (with dvd region killer installed). I also enabled sync data transfer and DMA which allowed me to burn my discs at 4x. I am using Princo white tops and before i enabled those 2 things it was writing at 4x although it took as long as a if i was writing at 2x. I haven't made a coaster yet.....touch wood!
MCRR-Electronic Forums
Moderator -
Take a look in your device manager under IDE ATA/ATAPI controllers, you will know where to look if you know what you're doingOriginally Posted by skinnyzaz
There's also some usefull info in this thread :
https://www.videohelp.com/forum/viewtopic.php?t=160637&highlight=
good luck,
Remco"Drawn beyond the lines of reason. Push the envelope. Watch it bend." -
Something that is recommended: make certain that you have the DVD burner set as the master on the IDE channel that you have it on. I have noticed in the past that this makes a difference.Could it have something to do with what IDE it is pluged into cause i might have changed that i cant remember.NickBurns - "It's the software that's stupid, not you... right?"
DVD Styler Fails to Burn
By mik1 in forum Authoring (DVD)Replies: 1Last Post: 10th Jun 2010, 02:57 -
Samsung 22x drives FAILS every 6th or 7th BURN HELP !! WEIRD !
By rockonvidtrade in forum DVD & Blu-ray WritersReplies: 3Last Post: 13th Feb 2010, 20:55 -
DL+ burn fails with ISO file larger than 7 Gig. Why?
By anubis13 in forum DVD RippingReplies: 5Last Post: 5th Dec 2009, 19:48 -
Burn fails while burning DVD video not data dvd
By cd090580 in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 02:27 -
dvd burn fails in all software authoring programs
By jfrenchu in forum Authoring (DVD)Replies: 8Last Post: 9th Feb 2008, 23:39
