I just dicovered that (NTSC) DVDs requires at least one AC3 or PCM audio-stream.
Since PCM is a waste of space (according to my opinion), I will choose AC3.
So I just wonder, is a 224 kbps AC3 (2ch) audio-stream equal (in quality) to a MP2 Layer 1 audio-stream with 224 kbps?
Thnx
Guest
The file sizes of mpeg audio and AC3 at the same bit-rate are almost identical. I leave it to the audiophiles to argue the fine points, but I think the sound is equivalent (although AC3 seems to have a lower "gain" (loudness) in my experience.)
By the way, you don't have to have either AC3 or PCM for your DVDs to work. Even if the authoring program "warns" you (like Maestro does) it will still go ahead and author it for you. The vast majority of players will play mpeg audio. It is just that the formal standard for NTSC DVDs say one or the other. So using AC3 gives you the most compatibility.
How to convert 5 ch. AC3 to 5 ch. MPEG-2 Layer II
By macman241 in forum AudioReplies: 21Last Post: 1st Sep 2016, 11:08 -
Audio duration change after transcoding from MP3 to MP2 or AC3
By darklock in forum AudioReplies: 3Last Post: 24th Feb 2012, 15:50 -
Converting MPEG2 Audio from AC3 to MPEG1 Layer 2
By jrisch in forum Video ConversionReplies: 8Last Post: 8th Dec 2009, 20:28 -
Convert MP2 to AC3 within VOB structure
By Xesdeeni in forum Authoring (DVD)Replies: 6Last Post: 4th Jul 2008, 14:19 -
Encode mpeg-1 layer 3 in AVI to AC3 surround in Nero Vision Express 3
By jimbojr in forum AudioReplies: 0Last Post: 18th Feb 2008, 19:51
