Hi. I have just got a DVD burner and I am very new to this. But I managed to author a DVD with the help of Ulead DVD Workshow (trial verison 1.3). On my first DVD burned, I had approx. 20 minutes of video on it. The second, third and forth DVD authored and burded I had approx. 2 hours and 10 minutes on the DVD. But all the DVD's I play on the player, exept for the first one, kind of skip som of the frames during play. And I can not live with this. An example: if I have a video of me saying: Hi, I come from Norway, and Iam new to this. I would hear during playback: Hi, I come from ... new to this. WHY? I use WinXP, my DVD Burner is Sony DRU500AX, and I use a NAD T570 DVD player for playback.
If anyone knows what might be the problem, please respond to my message. Thanks.
Brgds
Kenneth
It sounds like the combined bitrate might be too high, but then again, if you have 2h 10min on it it should not be like that. Check it anyways, the total combined bitrate cannot exceed 10.08 Mbit/sec
Also, are you burning to a rewritable? They are less compatible than write-once media, and I have found that DVD-RWs often exhibit minor glitches that don't appear when the same project is burned to a DVD-R.
KMplayer Skipping or Speeding-Up Frames
By Wanderlustus in forum Software PlayingReplies: 3Last Post: 26th Jan 2013, 23:38 -
AVI Problem - Skipping Frames
By gonwk in forum Newbie / General discussionsReplies: 4Last Post: 4th Dec 2011, 14:43 -
Sound skipping when playing mkvs
By vaati in forum Newbie / General discussionsReplies: 4Last Post: 14th Jul 2010, 23:12 -
Pixelation in certain frames while playing files in a DVD player
By aarelovich in forum Video ConversionReplies: 8Last Post: 4th Feb 2010, 15:47 -
XVID video is skipping frames...
By Da_Nuke in forum Video ConversionReplies: 3Last Post: 20th Jun 2008, 00:51
