Hi
i am trying my first attempt to put 2 svcd films on a dvdr. i am confused on the audio/video patching part. is it just the video you patch and then patch back to 480?? if so do i do whole file or first header?
about the audio which would be the best option to convert it to 48KHz.
pretty much ok so far except for this part. any help would be great. thanks a lot.![]()
one final question tho sorry, when authouring, i will use Maestro, how do i drop the two sets of m2v and ac3 files so i can create 2 vts sets? or would it be best to make 1 big one and just set the start menu to start from a chapter that begins the second movie??
thanks again.![]()
Results 1 to 1 of 1
Patching a MOV-file from 50 to 25 FPS without frameloss & re-encode?
By Oneirophile in forum EditingReplies: 1Last Post: 11th Oct 2011, 07:29 -
AVI broken header file
By magillagorilla in forum RestorationReplies: 3Last Post: 23rd Sep 2011, 10:01 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 12:26 -
can you edit the header of an mpg file
By lmwashere in forum EditingReplies: 9Last Post: 13th Nov 2009, 22:07 -
AC-3 file header errors?
By DRP in forum AudioReplies: 1Last Post: 28th Jun 2009, 00:24
