  1. I want to buy CD labels for 8CM CDs.
    You can hardly get them ANYWHERE.
    And where you can get them they're reeally expensive.
    Can anyone suggest where I can buy them at a good price.
    AND... I want to know what is so special about CD labels anyway?
    Aren't they JUST stickers?
    If that's the case, can I go to a printer and simply have blank ones made up?
    Pleeeease let me know. If that's the case, then it's definitely something I will consider.
    Thanks.
    Jam
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    http://www.pressit.com/p00993.htm
    SELLS 8CM label...
    but maybe you should buy regular ones and cut them with a strait edged tool...or a round edged tool..is there such?
    I would not make my own less I knew the glue was the same and thickness too!
