hi there
I'm using Virtual-Dub 1.5.4(not the pentium 4 version)
I can't get higher than 128KBPS bit rate
Can anyone tell me what is needed?
everytime I try to re-encode a mpg - avi file......they said ACM can't compress the audio or something like that.
I'm using Pentium III 1Ghz
512MB SDRAM
Hi! Maybe a dumb question but do you have the audio set for Audio->"full processing"? If it's set to direct stream copy then you can't really do anything to it.
NitemareEven a broken clock is right twice a day. -
What about the "audio conversion" setting? I'm grasping at straws here ...
Converting Avi to Mpg using ffmpeg
By sumit_pankaj in forum Video ConversionReplies: 5Last Post: 31st May 2020, 20:42 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 07:30 -
converting flv to avi/mpg
By nimrodm in forum Video ConversionReplies: 1Last Post: 14th Feb 2010, 07:05 -
Converting MPG to AVI type2 (batch)
By statman24 in forum Video ConversionReplies: 8Last Post: 19th Jul 2007, 04:30 -
Problem converting from .AVI or .MPG -> DVD
By ConaHead in forum Video ConversionReplies: 9Last Post: 15th May 2007, 22:13
