I have an Xvid file with a resolution of 640x272 (Panavision). What do I have to do to keep the aspect ratio and add the proper amount of black bars in FfmpegX? The 16:9 button obviously won't do for that... Yes, I already tested it![]()
AnonymousGuest
AnonymousGuest
uhm, yes, sorry: I want to make it into some SVCDs. I thought ".mov" was a typical QuickTime extension? But this file won't play/decode with any other thing than mplayer. I will surely try it if the solution comes from you, but care to enlighten me as for why ".mov"?
And do I use the 16:9 button additionally?
AnonymousGuest
Doesn't work. Same result: There are some small black bars, but they should be much wider for Panavision. Funny thing: Normally FfmpegX starts to encode the sound at the same time, putting a temp file for that in my home folder. Now it didn't. All I changed was the ".mov" extension
AnonymousGuest
K, what I try now: Using ".mov" extension and 16:9 together. Looks good so far. I hope it will playback fine on my TV/DVD player...
But in the terminal it clearly says now:
"Audio: no sound
Freeing 0 unused audio chunks"
This is not good?
I thought what was recommended was to convert the XVID/DIVX .AVI file to a more Quicktime friendly .MOV with the DivX Doctor II application from http://versiontracker.com/dyn/moreinfo/macosx/14266 not just changing the extension from .AVI to .MOV in the finder/terminal window.
That works well for me when creating VCD with ffmpegX.
My question about the Aspect ratio is that I choose to encode a 640x480 DivX file for a XVCD as 720x480. The quicktime player displays the resulting muxed MPEG1 file as 652x480. Mplayer and Vlan show it as the expected 720x480 ratio. What's up with that? I assume the latter two players are correct and Quicktime is incorrect.
Seems to work okay when burned as an XVCD.
16:9 Aspect ratio
By jeffh123 in forum Video Streaming DownloadingReplies: 5Last Post: 30th Aug 2011, 19:44 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 17:40 -
Aspect ratio help
By kkiller23 in forum Newbie / General discussionsReplies: 5Last Post: 27th Sep 2008, 07:21 -
Aspect ratio
By Digiface in forum Software PlayingReplies: 2Last Post: 24th Aug 2007, 12:35 -
Aspect Ratio's
By AndySpring in forum Newbie / General discussionsReplies: 7Last Post: 23rd May 2007, 12:55
