Hello,
Everything is working fine, but I have one problem, I have 2 audio soundtracks for a movie (5.1 stereo and 2.0 stereo with commentary). With DVDlab I can only put 1 soundtrack but I want them both. Is it possible ?
THanks
Kalemvar
Don't think so... I am almost sure dvdlab only supports one audio track. Though I think there is discussion on adding support for more...
If the Apocalypse comes...Beep Me - Buffy -
While DVDLab doesn't support multiple tracks (or subtitles) right now, there is a workaround. Basically you author the VOBs the way you want them and import them into DVDLab without demuxing.
At that point you won't be able to author a switch among audio, but you can use your remote control on your DVD player to switch among the tracks. Not the best solution and eventually DVDLab will have multiple audio support."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
How to create an Audio-Only DVD in DVDLab Pro (IMPROVED)
By GordRocks in forum User guidesReplies: 26Last Post: 15th Jun 2023, 07:55 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 01:05 -
DVDLab Audio Playback
By alhall in forum Authoring (DVD)Replies: 1Last Post: 26th May 2008, 10:00 -
How to create an Audio-Only DVD in DVDLab Pro (PART 1)
By GordRocks in forum User guidesReplies: 28Last Post: 7th Oct 2007, 01:53 -
Is there any other software like dvdlab?
By anfield7 in forum Newbie / General discussionsReplies: 7Last Post: 1st Oct 2007, 05:55
