I used DVD2SVCD to convert an hour and 40 minute Divx video to SVCD, using TMPGEnc as the encoder. The end result when played on PowerDVD and my standalone DVD player has red ghosts where any movement is. The more movement in one place, the darker the red ghost gets, then resets about every 12 seconds.
Can anyone give me any suggestions as to what settings I can tweak to fix this? It's really getting to me because the total encoding took 7 hours, and the picture quality is beautiful besides the motion ghosts
What happened when you set the Ghost Reduction in the Advanced tab in TMPGEnc? Remember you only need to do a sample to find out if a setting works. May save you another seven hours 8)
Hello. -
Is there an option to do a sample encoding, or do I have to manually edit a sample of the video? Thanks.
No. Just use the settings you would for normal encoding. When the output reaches a certain length you desire, stop the encoding. The output will only contain the video up to the point where you aborted the process.
Hello.
Conversion causes only red text to be smeared?
By InvisibleMan in forum Video ConversionReplies: 4Last Post: 30th Apr 2010, 21:02 -
Best Conversion from AVI (Motion JPEG) to MP4
By cademichaels in forum Video ConversionReplies: 3Last Post: 12th Apr 2010, 21:34 -
Conversion divx to svcd gives Choppy Playback
By Soixante in forum Video ConversionReplies: 2Last Post: 17th Nov 2009, 06:25 -
I need a genuis!!! Heavily red tinted or red hue.
By mikekrauser in forum Authoring (DVD)Replies: 4Last Post: 16th Aug 2009, 19:51 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 20:11
