After reading Shocan's excellent guide about the settings for TMPGEnc I am a little confused about the setting to use in the video source. The How-To guide says to use 1:1 VGA. The guide explains that 4:3 is for sources encoded for TV and 1:1 VGA for sources encoded for computer video. I feel that I should use 4:3 since even though I'm capturing from my computer the source was still encoded for TV. Am I right?
That's what I would do. I think people get confused with resolution and DAR (display aspect ratio). You PC monitor has a DAR of 1:1. Your TV has a DAR of 4:3. Most movies are shot at 16:9. However, I can get these DARs at any resolution. Take a look at:
http://www.doom9.org/aspectratios.htm
for more info. -
I use this very simple rule of thumb
for source
if it is 352x240 source is NTSC 4:3
if it is 352x288 source is PAL 4:3
if it is any size other I use 1:1
TMPGEnc is very good with the resize - it will take very odd sized DivX's 360x615 and strange stuff like that and correctly resize it to 4:3 -
Cool, thanks guys! One more thing, if I've already deinterlaced my video source in VirtualDub then I don't have to select "Interlaced" in the Video Source Type in the Advanced type right?
Blu-Ray 1080i source > MKV, confused about deinterlacing
By Phat J in forum Video ConversionReplies: 0Last Post: 25th Aug 2011, 00:42 -
Understanding TMPGEnc source material settings
By brassplyer in forum Video ConversionReplies: 1Last Post: 5th Mar 2011, 07:41 -
confused with avi settings:
By modern saviour in forum Video ConversionReplies: 3Last Post: 4th Oct 2010, 15:52 -
Confused about capturing VHS source to PC
By nomad2224 in forum Newbie / General discussionsReplies: 21Last Post: 13th Sep 2009, 14:43 -
Capturing video... confused about some of the settings
By Cyber Akuma in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2009, 12:05
