I have made 3 dvdsvcd's with this program, but after the last update I made a dvdsvcd and when I play it in my Panasonic DVD player it looks like the pic is going up and down and does not stop. It works on my Apex, but that's a piece of crap. I have gotten the other DVDsvcd's to work fine on the Panasonic. Any insight would be appreciated.
The dvdfolders "engine" has not changed recently. Does this v-hold thing happen when you re-author the ones you did before your last update?
I ran into the same problem on my new Panasonic F85 DVD player. I used svcd2dvd+ to make the DVD folders (from svcd sources) and then burned the folders with Nero. The disk played fine on my computer in the drive that made it, but I got the v-hold problem in the stand-alone player. I think I might try copy2dvd to burn the disk and see if that works.
The SVCD source disk works fine
Henry
Standalone DVR's with HDD's - how much can they REALLY hold?
By m3 in forum DVD & Blu-ray RecordersReplies: 32Last Post: 26th Jun 2011, 15:54 -
it may be smart of hold off on sandy bridge...
By deadrats in forum ComputerReplies: 2Last Post: 12th Feb 2011, 22:04 -
Those discs which hold 25 - 50 GB of data.. are they worth it??
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 7th Nov 2010, 19:50 -
what size of the movie a dvd can hold?
By volam in forum Authoring (DVD)Replies: 13Last Post: 27th Mar 2008, 16:37 -
Vertical hold problem with Majix PhotoStory 5
By pdvdr in forum Newbie / General discussionsReplies: 2Last Post: 28th Jul 2007, 11:10
