After using DVD2AVI to extract 2 files from DVD, I have 2 files : the first file is .d2v and the second file is .lpcm. When I tried to import to DVD Maestro it only accept the .lpcm file but it rejected .d2v file. Can someone help me to make my .d2v file accept by DVD Maestro? Thank you.
The d2v file is generated for use with TMPGENC only
Once you run the audio and Video files (pcm and d2v) through the selected script in TMPG you then will have a new mpg
Use mpg tools inside TMPG and De-multiplex your video and audio streams
Load them up into your authoring program...
Hope this helps -
I am planning to use DVD Maestro to do DVD author. Do you have any idea how I can import this .d2v to DVD Maestro. Thank you.
a d2v and a m2v are 2 totally different types of file a d2v is more like a playlist of sorts and a m2v is a video file.
[ = Check out my band @ www.samadhirock.com = ] -
Well in a way you can, just run it trough TMPGEnc and encode a compilant MPEG stream, then remove the .d2v file.
Voilá! -
d2v filed are just a way to frameserve your .vob files to a encoding program. Kinda like an file interpreter for a program to read the vobs. you can also feed this system to CCE for encoding via an avisynth. As you can see by the size of the d2v file, it is a very small language file just used as an in between for the larger files.
http://www.dvd9to5.com/DVD2AVI.htm
http://www.dvd9to5.com/TMPGEnc.htm
Dd
PS: vobs can now also be fed directly to CCE via a small plug in for a avisynth. This eliminates the need to even create a d2v, it preforms the task for you when feeding to CCE. I not done a lot of testing of this plug in but it looks promising.
Mpg2dec plug in
http://www.avisynth.org/users/warpenterprises/(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
How to convert a .ts in PAL format to a .ts NTSC format???
By jwmghf in forum Video ConversionReplies: 4Last Post: 4th Sep 2011, 09:40 -
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 07:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
