  1. I've evidently screwed up a mpg and didn't notice it till after I deleted the avi file. Didn't have much disk space. Anyway, I'm trying to make a DVD but my video size is 352x480. Is there a chance I can convert that to standard DVD size? I used TMPGEnc Plus 2.5 to encode and am using DVD Movie Factory to create the DVD. I've tried opening the file using TMPGEnc but it crashes everytime.
    Paul
  2. DVD MF2 should accept that resolution as it is a valid DVD Resolution.
    Maybe something else is wrong with it? Audio or maybe video bitrate?
    I use mpegproperties, Use it to see what the files properties are. It has a link under tools on the left.
    More info beyond just resolution of the video will be needed for anybody to help.
  3. Here's some file information...
    Num. of picture read: 4453
    Stream type: MPEG-2 MP@ML CBR
    Resolution: 352*480
    Aspect ratio: 4:3 Generic
    Framerate: 29.97
    Nom. bitrate: 3000000 Bit/Sec
    VBV buffer size: 112
    Constrained param. flag: No
    Chroma format: 4:2:0
    DCT precision: 9
    Pic. structure: Frame
    Field topfirst: No
    DCT type: Field
    Quantscale: Nonlinear
    Scan type: Alternate
    Frame type: Interlaced
    It should work fine to author that mpg to DVD without any reconverting.
  5. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    FYI,
    An Mpeg2 with that resolution is commonly called 1/2 DVD or CVD. Many people make CVD's (basically an SVCD at 350x480) in anticipation of getting a DVD burner sometime later and easily converting their disks.
    8)
