  1. Hi,
    I have made a DVD that is 6GBs ----too big
    So I decided to make 2 DVDs instead.
    When I go to edit the movie in Architect it allows you to set in and out points.
    However it still uses the same amount of disk space. Is there a way to change this? See pic below
    Thanks in advance
  2. Soo just to follow up I want to cut away the dark part of the timeline...
  3. did u try dragging on the timeline itself (end/start) ??
    click on end of timeline & drag it to position
