I'm using a Dazzle "digital video creator" capture box thing (i'm a noob at capturing, can you tell?). Right now, i have to use the special software that shipped with my Dazzle thing to capture the video from my camcorder. Ideally, i'd like to be able to click "Capture" in adobe premiere 6.5 and have it work, but it won't work. Can you use a Dazzle capture (card?) to capture the video from a camcorder to adobe premiere? Or is dazzle to cheap of a capture card to work with Premiere?
Thanks for any input!
I think what you'll have to do is double-check to see what the Dazzle thing creates on capture: Microsoft .avi or Mpeg1 or 2. I don't think the new Premiere version will accept an MPEG file, so that might be your problem. You could also go to the dazzle website and see if there's a patch or update that will make it work with different editing programs.
Computer trouble with Adobe Premiere & Photoshop CS4
By monks19 in forum ComputerReplies: 3Last Post: 10th Jan 2011, 13:42 -
Trouble Importing avi file into Adobe Premiere
By Top Gun in forum Newbie / General discussionsReplies: 8Last Post: 18th Jul 2010, 14:21 -
Problems Capturing/Importing Video into Adobe Premiere Pro
By Texas in forum EditingReplies: 3Last Post: 15th Apr 2010, 02:56 -
Capturing Video to Adobe Premiere CS3 (USB)
By Haz567_a in forum Capturing and VCRReplies: 4Last Post: 27th Jul 2008, 03:31 -
trouble authoring mpg files made in Adobe Premiere Elements 3.0
By compaqted in forum Authoring (DVD)Replies: 3Last Post: 10th Dec 2007, 00:14
