I have a WinTV-GO card in my computer but... I seem to be getting interference from somewhere as the picture is very bad when I capture from VHS(even the plain blue screen looks terrible). I capture in the newest Virtualdub and I am using the newest drivers. I have been able to use some filters to make anime look awesome using it(thanks to lukesvideo) but haven't got the knack with live action. I was wondering if anyone has found a good solution. Or is my best solution to do all my anime first then get a better card after that's all done?
I have ran into this pronlem, one cure make sure your VHS machine is only hooked up to the computer and no where else.
Do not have the Ant. Cable hooked up or any RCA cables to your Home Entertainmant System from your VHS Dsek. Everytime I either use my SVHS deck, DVD or Laser Disc I disconect all the cables except the ones going directly to my computer. -
1)Win98SE
2)Its hooked up to nothing but the comp. I unhook the VCR and I move it by my comp and use my RCA cable to hook it up (its shielded so it shouldn't be picking up interference
Wintv
By maryhigginsrice in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 20:36 -
Wish List recording in WinTV-7?
By pglenn in forum Capturing and VCRReplies: 5Last Post: 3rd Mar 2011, 17:52 -
wintv alternative?
By sitlet in forum Capturing and VCRReplies: 0Last Post: 6th Jan 2009, 15:29 -
WinTv
By maryhigginsrice in forum Capturing and VCRReplies: 3Last Post: 24th Nov 2008, 18:54 -
alternative to wintv ??
By jaxxboss in forum Capturing and VCRReplies: 2Last Post: 28th Jul 2008, 21:04
