  1. I have a mpeg-2 video file with the right video format for a DVD but with the audio is 44100. I need to convert it to 48000. What should I do?
    Any hints?
  2. Member wulf109's Avatar
    Jul 2002
    Tmpeg can convert the audio from 44100 to 48000. Just select audio only and select 48000 for your sampling rate.
    Ifoedit 0.95 will author a DVD from 44100 audio,I've done it. Your DVD player might not support DVD playback with 44100 sound so make a test on a DVD-DW.
  3. Hi Wulf,
    How do I do it? Is there any totorial here in this site? Do I have to demultiplex it first and then convert the audio?
    I can only open the file in MPEG Tools in Tmpeg. If I try to open it anywhere else it says it's not compatible. What changes should I make?
    Thanks!!
    using tmpgenc to convert to 48 khz:
    www.dvdrhelp.com/vcddvdr#problems
