  1. I have many DVD-R's that I would like to make copies of using my Sony DRU-510A drive, mostly onto DVD-R, some onto DVD+R. The problem is I don't know how to easily copy them. They were copied off of TV so are unprotected DVD's. I have Nero 5.5.10.20 which I figured would easily do a copy of a DVD. When I try to though it says it can only copy the first track so I know that's not a complete copy. Then I decided to do a copy where I would select the files off the original DVD (which of course I would select all files) and then drag them over to the target DVD. When I do this though it says it's not enough space (even though it's only around 3.5 gigs). Am I doing something wrong with Nero or is there maybe a newer version that would work? Is there another copy program that woudl work? I am doing complete copies of unprotected DVD's so as I said I just want a simple program that will do this. Thanks.
  2. surely there should be some "disc copy" option in nero?
    Swim with me
    And we'll escape
    All the trouble
    Of the present age
    Finally free
