Produced my first disk (using the Pioneer fix ) and each chapter will only play for 1 to 3 sec then freezes.
I converted a 3 disk svcd and used the AC3 option.
Any ideas ?
cheers
Neil
ps, plays fine on the PC....but don't they always.....
neil88Guest
I had a problem with the AC3 audio produced by BeSweet on my Pioneer standalone. It seem that Pioneer players don't like what BeSweet does. The effect is that the DVD will play for a couple seconds then freeze up.
My solution? I bought Vegas+DVD for $265 which comes with a licensed Dolby Digital AC-3 2.0 or 5.1 Encoder. Overkill, maybe, but I have Video Factory by the same company (Sonic Foundry) and it's one of the easiest NLE's to use on the market; much simpler than Premeire.
Check to see if your DVD will play on any other players, and try encoding the audio to MPEG-2 sound and see if that works. Note that some players don't like the MPEG-2 encoding either. -
Of course some of our Pioneers have OTHER issues when the files are encoded to MP2, but that's another issue entirely.
- Gurm -
ok i sorted it anyway thanks for this topic, Helped me out anyway. Converted to MP2 w/ tmpeg instead of AC3 w/ bsweet.
Player played the whole film fine.
PS. who would of thought the sound file, would of caused this much problems for me.http://dvd.coldpie.com - where you can download versions of DVD2DVDR. -
Yeah, the Pioneer players are a bit finiky sometimes. If you want "true" audio compliance, you have to spend bucks to get an official licensed Dolby AC-3 encoder. I bought Vegas+DVD from Sonic Foundry, it's an NLE that comes with the Dolby encoder. Easy to use too, and you can frameserve to TMPEGEnc if you don't like it's own MPEG-2 encoder.
It's that or wait for BeSweet to adjust it's AC-3 encoder to work on Pioneer players.
MEGui FREEZES!!
By mark63534 in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 20:43 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 05:49 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 00:35 -
XP freezes momentarily
By sdlehman in forum ComputerReplies: 12Last Post: 11th Aug 2008, 16:01 -
how to filter away freezes ?
By cyflyer in forum MediaReplies: 3Last Post: 24th Feb 2008, 16:51
