Does previewing in TMPGEnc slow it down speed it up or nothing at all? just wondering if i should have it turned off thinning or display all
Andy
If a computer Bites you BYTE it back -
It can't be that much of a difference. It only shows one frame every few seconds. I kind of like to see what's going on. Do a test with and without, see if you notice a difference.
How do you preview it mine use to and now it doesnt so im not sure if its working or not
Option > Preview Option > Display with thinning or display every frame
up to u which one you useAndy
Maybe a daft question but what is the point in previewing?
It doesnt show the end product eg theres no sound and its so choppy the playback it bears no resemblance to the finished encode.
Tell me if im talkin rubbish -
No...your not talking rubbish.
The only worth while preview you can do is to start the encode,stop it after a few minutes and check out the results (the only thing is that if its one of those gradual out of sync encodes then ...you s.o.o.l"Today is only yesterdays tomorrow" -
The pictures it shows are the once just encoded, hence is it more or less just dumping from memmory to the screen, as well as saving to HD. This should not affect much.
the help file in tmpgenc says previewing will slow down the encode because processing time is used the render the preview pic.
Video lags, drags, stutters when previewing in Adobe Premiere Elements...
By Captain Satellite in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2010, 08:13 -
Suggestion for good software for previewing capture?
By The Kitchen Sink in forum Capturing and VCRReplies: 3Last Post: 26th Aug 2009, 09:26 -
Previewing and adding subs
By lucho89 in forum ffmpegX general discussionReplies: 1Last Post: 2nd Aug 2008, 07:28 -
Error after Previewing video + font problem
By ayamefan13 in forum ffmpegX general discussionReplies: 9Last Post: 9th Feb 2008, 18:30 -
tmpgenc slow dvd authoring
By mystic818 in forum Authoring (DVD)Replies: 2Last Post: 20th Nov 2007, 05:21
