I am new (so new I do not have the hardware yet) on this topic but have a saving plan on track for a nice new PC, this is to include a DVDrw.
Really a couple of questions.
1. With software as it stands today, is it easy for a novice user to effectively copy a DVD and keep at least the sounds options with the main movie and then burn it successfully.
2. What is the best DVD writer to go for, should i get a combi writer that does both - & + or is the pioneer range established enough to just stick with -
All on target to get the new PC (specially built) in October. Thanks for help guidance and suggestions.....IS
If I Appear Stupid, It's Because I Am
The DVD X Copy program works fine and does that you ask and is dead easy to use!
What is the best current AVI to MPEG 2 converting software?
By avz10 in forum Video ConversionReplies: 8Last Post: 2nd May 2012, 17:00 -
Best FREE (not a trial) EASY software to convert UTube movies onto a DVD???
By jacknscoob in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2012, 01:37 -
Best current software for BD ripping
By rocks911 in forum Blu-ray RippingReplies: 4Last Post: 15th Dec 2011, 10:20 -
Recommended high quality/easy DV->DVD software?
By mkanar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Apr 2010, 15:07 -
Easy DVD Creator by Ether Software
By DW49 in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 14:33
