What size do I need to capture for best results for making DVDS of home movies?720*480, or 352*480
this is dependant on a few things.
if your final file is going to be 720X480, then you should cap in that resolution. if it's going to be 352X480, then cap in that. but which resolution is best to use in the end? well a lot of poeple will tell you to use 352X480, as your source will be low quality anyway. i say, capture the same clip in both resolutions, and make up your own mind. the advantage of using 352X480 is that you can fit about 2.5 hours of acceptable quality video on one disc, wheras 720X480 is more like 90 minutes, but again, try for yourself and see which result you prefer. -
my sonic dvd strecthes whatever sizeto make it dvd comliant ,what size is dvd compliant?
there are several DVD compliant resolutions. you can look at the What Is? section over there <----------------------
they are
352X240, 352X480, 704X480, 720X480. those are the NTSC ones, the PAL ones are 352X288, 352X576, 704X576 and 720X576.
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 18:29 -
VHS Capture Size Massive?
By donkey33 in forum Capturing and VCRReplies: 17Last Post: 24th Feb 2011, 01:40 -
Size to Capture VHS at for DVD
By MasterOfPuppets in forum Capturing and VCRReplies: 4Last Post: 3rd Mar 2010, 17:15 -
Size of Capture file
By gasport in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2009, 16:46 -
lower file size for a capture
By matneaves in forum Video ConversionReplies: 6Last Post: 1st Sep 2007, 12:34
