  1. When I try to burn to Bulkpaq 4xspeed DVD-R disks I get "Illegal medium" and then "Could not perform start of Disk-at-Once" I have no problems with other media, however they are slower speed disks. I am usind a NEC 1300 burner. Anybody got any ideas?
    Thanks!
  2. NEC 1300 burner have a lot of problem with cheap DVD-R Media..
    You will need to use DVD+R or only branded DVD-R (that cost way more)
  3. What kind of software that you use to burn???
  4. I am using Nero 5.5.10.28 Enterprise Edition
  5. Originally Posted by Spooks
    it is not the software, it's the drive fault.. Take a look at DVD Writer review on you left.. you will see the nec drive don't like cheap DVD-R
  6. I always use the version Nero Express which is a small part of nero then use option dvd file then add dvd files that you have ripped from dvd disc and just burn it. Remember to choose your dvd burner on the top right of the first screen of Nero Express.
    Good luck.
