Hey guys.I have a movie in a .bin file and the file is to big to burn to a disk so i need a program that will let me open the bin file and get the movie so i can re-encode it or split it. Anyone know of any progs like this? I checked the tools section but couldnt find anything. Any help is very much appreciated.
Also if you guys have any input on what would be the best thing to do with that movie..split it or re-encode it..its a svcd file and its already been encoded and everything. Thanks muchly.![]()
how big is the file? I have seen a few which should have been to big for a disc but burned anyway.
its 840 megs..i tried to burn it with nero but came up saying the file was to big for my disk. For some reason im thinkin there is an option in nero to make it so it will make it fit on the disk..maybe im wrong..just came to me..hehe
try isobuster, i think it can allow you to extract the movie out of the bin file.
Daemon tools should let you mount it as a virtual cd and get the files off of it also.
Also the VideoLan or as its sometimes called VLC player will let you play the movie on the PC without even mounting it. Of course that only helps if you want to watch it on your PC.
For AVG users (missing bin file)
By stiltman in forum ComputerReplies: 6Last Post: 17th Aug 2008, 23:16 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 11:58 -
Opening .bin file jpg
By chewie8008 in forum ComputerReplies: 4Last Post: 18th Jul 2007, 16:01 -
Bin file
By anton225 in forum Video ConversionReplies: 3Last Post: 4th Jul 2007, 13:05 -
how to burn a BIN File
By Chris 67 in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2007, 07:44
