I've made an svcd converted from an avi-file, i wrote the svcd, watched to control the quality on my stand-alone dvd-player, deleted original from hard disc.
Now i need to get the mpg back of the svcd to do some video editing, but when i try to copy the mpg file to my hard disc copying starts, but when it reaches the end of the file it gives me an error and deletes the file on my hard disc again.
How can i "rip" my mpeg2 file back so i can edit it ?
sounds like you may have chosen "cut" instead of "copy" when you tried to put the file back to hard drive
I have the same problem on my NT machine at work. I have no idea what is causing this. I can copy it over on my Win98 machine, but then all I can do is play the file. I can use TSCV to make another image to burn. It gives an error and says the file is in use (even though it is not).
REALLY STRANGE RARE THING: MPG video CHANGED after file transfer or copy
By xboxsold in forum Newbie / General discussionsReplies: 21Last Post: 1st Feb 2011, 10:28 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
cannot copy 22.5 Gbyte file with Win XP copy command
By maxtrack in forum Newbie / General discussionsReplies: 7Last Post: 2nd Aug 2007, 15:12 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
