ive got an avi file which i want to convert so it will go in to tmpgenc.
what programme can i use and how do i do it.
Its all for files to go in movie factory 2 without having mf2 to convert it itself.
If I'm not mistaken, tmpgenc can read avi files directly. Just drag or browse and select. Tmpgenc may not be able to handle all codecs for avi, however.
If tmpgenc says that it the avi is not supported you may want to bring the avi into virtualdub (vd) and check for errors. Then output the avi using a different codec (like hufyuv, if you have it).
You can also bring the file into vd and frameserve to tmpgenc. There is a guide around here somewhere for doing frameserving from vd.
-- Styro -
tmpgenc will read most all avi files but you may need to change the avi reader prioritys in the vfapi reader settings ... there will be two avi file readers listed and sometimes you will need to change both of thier priorities (dont make them the same) - make one high and the other low and if that doesnt work - reverse it ..
Convert AVI to ? to TMPGEnc DVDAuthor with 5.1 audio
By NDMMackay in forum Video ConversionReplies: 2Last Post: 15th Oct 2011, 07:02 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
TMPGenc CAN NOT CONVERT AVI LF RT CHANNELS TO 2 AUDIOS
By suijaypao in forum Video ConversionReplies: 3Last Post: 14th Nov 2009, 05:03 -
Batch convert DV-AVI to MPEG2
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 27th Sep 2009, 15:08 -
How to convert Mpeg2 to DivX using TMPGEnc and SimpleDivX
By rwmol in forum User guidesReplies: 14Last Post: 29th Jul 2007, 23:57
