Since you are able to shift various filters up and down on the list once you "add" them, is there any benefit to having some filters higher in the list assuming such filter get applied first and if so what are any pitfalls in setting the order incorrectly or does it really matter?
With some filters the order they are in really does matter. For example, the logoaway filter needs to be on top to work. If you use it after any filter it won't. You might need to experiment with them in order to get the optimal order. You also need to become familiar with how the ones you use most often work. I use logoaway, resize, deinterlace and 2d cleaner in that order. With some exceptions it really helps to put all other filters after the resize filter since obviously a smaller file will be processed faster.
Problem using wipeout filter in virtualdub
By ahmed_mo2nis in forum Newbie / General discussionsReplies: 15Last Post: 8th Mar 2011, 23:53 -
VirtualDub: Layer Filter
By creamcone in forum EditingReplies: 6Last Post: 26th Dec 2010, 12:27 -
VirtualDub filter
By nic3 in forum EditingReplies: 6Last Post: 30th Sep 2010, 10:48 -
VirtualDub Filter Blending
By sambat in forum EditingReplies: 4Last Post: 6th Sep 2009, 15:07 -
VirtualDub Filter During Capture?
By CosmicOutburst in forum Newbie / General discussionsReplies: 4Last Post: 26th Nov 2007, 19:48
