hi, is there any way to convert an avi film to burn on a dvd without having to split the avi in 2 before burning, so as to get the whole film on one disc? as at the moment i have to use 2 discs to fit 1 file and it nearly fills both discs.
cheers
questions -
how big is the file?
do you want to play this on a dvd player, or just keep it as a data disc?
If you want this to play on a dvd player, you need to convert the .avi to mpeg, and then author a disc. check the guides on the left side in the Convert section.
If you just want to archive this on a disc to play as an .avi on your computer, I would suggest reencoding it with a codec that takes up less space.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
file is 700mb i want to be able to play it on my dvd player not the pc. as i said when i encode it i end up with a file that is too big for 1 dvd
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
