OK, I'm getting very frustrated/confused about audio. What is the audio setting I use for DVD2AVI? I am interested in SVCD production.
I plan on using TMPGEnc for my encoding, but I've never been happy with the audio. I have used Lame as an external encoder and the audio has improved, but I want the best possible sound!
Should I create AC3, convert it to MP2; or use DVD2AVI to create WAV; what settings do I use? Demux? Decode? WHAT DOES IT ALL MEAN???
From the sound of it, your using DVD2AVI to open VOB/MPEG, and saving it as an AVI/Project file, and an audio file.
The options are simple.
Under the Audio Menu:
Track Number:
Set this to #1. This is usually the track you want to extract. It can change for a DVD source (say for multiple languages). If your not sure which you need, pick #1
Channel Format:
Set this to Auto Select. It will automatically detect what format the track audio is stored in, and decode as needed.
Dolby Digital:
To demux the audio directly from your source MPEG, select DEMUX.
If you want all of the audio tracks from your source (A DVD often has multiple audio tracks), select "Demux All Tracks".
If you want the audio converted to WAV, no matter what format it is in, select "Decode"
Leave the Dynamic Range Control Off.
Ensure Dolby Surround Downmix is selected. This is so the downmix for 5.1 surround sound comes out nice and balanced and the volume levels are corect.
MPEG Audio
set this on Demux
48 -> 44.1Khz menu
Set this to High if you are converting a DVD source to SVCD/CVD/VCD. If your source MPEG is aready SVCD/CVD, then leave this off.
Normalization
Should be left off. Use this only if the audio is too loud, or too soft throughout the whole movie.Impossible to see the future is. The Dark Side clouds everything...
Audio Player with stereo-to-AC3 encoding & user graph playback ?
By zamar27 in forum AudioReplies: 1Last Post: 11th Feb 2012, 17:21 -
HCbatchGUI user guide ~ Batch process video and audio.
By freebird73717 in forum User guidesReplies: 4Last Post: 21st Dec 2009, 07:51 -
User friendly/reliable audio/video synch tool Vista compatible
By wetcamelfood in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 18:03 -
Vegas Pro 8 user with questions about program (and possible camera settings
By chuchunezbie in forum Newbie / General discussionsReplies: 0Last Post: 27th Apr 2009, 16:32 -
Need Assistance With TDA 3 Audio (and or Audio Settings)
By isamudysan in forum Authoring (DVD)Replies: 0Last Post: 4th Mar 2008, 21:41
