I have downloaded a bunch of .rar files and cannot extract them. I right-clicked on the first one (xxxxxxxx.r00) and when I try it extract it I get an error. SOmething about a previous part needed to extract the file. I don't have enything lower than .r00. .
any help is appreciated.
Hi There,
What you need to do is to scroll down to the very last rar file, it should say something like xxxxxxxxx.rar.
You extract the contents using the .rar file and not the xxxxxxx.000 file.
Now if you don't have the .rar file then try to get it from where-ever you got the rest.
If you have rar files that start with xxxxxxxxx.001 then you just click on that and extract the contents.
Hope that helps.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H -
thank you marvel. I believe that did the trick. I really appreciate it, I have been fighting with this off and on all day.
de -
marvel
I must have missed the .rar when I downloaded it. I managed to get it and everything worked fine.
Thanks again.
de
extracting .flac files with WINRAR
By burgkev in forum Newbie / General discussionsReplies: 9Last Post: 20th Apr 2010, 18:39 -
winrar problem
By catonic2206 in forum Newbie / General discussionsReplies: 6Last Post: 13th Dec 2009, 12:27 -
problems with winrar
By kennyjunior in forum Video ConversionReplies: 1Last Post: 19th Nov 2007, 13:00 -
Splitting with winrar?
By chronic777 in forum Off topicReplies: 0Last Post: 17th Aug 2007, 08:17 -
Winrar error
By alintatoc in forum Newbie / General discussionsReplies: 17Last Post: 28th Jul 2007, 07:04
