Hi,
Have asked this question before in an other forum without much success so will give it a bash here.
I have the + version of the software, and everry movie i try to convert plays ok in my pc but when i put it into my dvd player i get a half fuzzy picture half green picture on the TV screen. I have a TOSHIBA dvd player which has never had any problems playing anything before.
Any else come across this problem?
cheers john
AnonymousGuest
AnonymousGuest
I to have a simalr problem. After running the trial version my output video (while playing with powerdvd) has the left side of the picture "fuzzed" out. I can still see its there but not watchable at all, don't know if this is because i'm trying to watch on my pc but want to try it out before i make a coaster. Any ideas?
AnonymousGuest
i'm having the exact same problem. this is happening with both PAL and NTSC SVCDs. plays fine on both my PC and XBOX, but on the TV with a Toshiba SD-2800 i get a split screen: bottom half is all green and the top half is the movie, but split screen.
Is the common ground here the Toshiba DVD player?
Heh. Now we're gonna have a "Toshiba Fix" and a "Pioneer Fix". *wink*
- Gurm
Could I use a green fabric as a green screen? Where could I get fabric?
By bojadada in forum Off topicReplies: 2Last Post: 5th Dec 2009, 11:48 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
Half the disk is formatted PAL, the other half NTSC...Doable or not???
By AlecWest in forum Authoring (DVD)Replies: 15Last Post: 16th Oct 2007, 08:31 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 10:55
