  1. Banned
    May 2003
    Dallas
    One of my home movies is over 700mb and I dont have a dvd drive so I am forced to put them on cd-r's. But the home movies are .bin and .cue and one is about 750 and the other is about the same size. Is there anyway I can break up .bin and .cue or could I fit them on 700mb somehow. I am trying to get them to me downstairs computer. If you have and help it would be greatly appreaciated. Thanks
  2. If you are talking about creating a VCD then you can fit approx 800mb or 80mins of video on a 700mb cd. Just load the cue file into your burning software such as nero, and you should find that it will fit just fine.
  3. Banned
    May 2003
    Dallas
    Great, Thanks Alot Man!
