  1. I have a .bin file and no .cue file. I downloaded GNU VCDImager Tools GUI for Win32 and I went under the Special/Additional tab. I clicked on Generator and located my .bin file to try and generate a .cue file for it. It gives me an error and says my .bin file is not a (S)VCD format????? But the other .bin for disk 2 (it had the cue file with it so I didn't have to generate one) burned fine.
    Any ideas?
  2. Something to try, no guarantees.
    Take the .cue file for disk2, copy it an rename it as the .cue file for disk1. Now open this file in notepad and look for the .bin filename. Change this to match the .bin for disk and, save and close. Now with any lucj you should be able to burn using your favourite burning software.
    You never know, it might just work!
  3. I will try this as soon as I get home today. Anybody had any succes with this? Any other ideas in the mean time? thanks alot for your help bugster.
  4. Member DJRumpy's Avatar
    Dallas, Texas
    It's easier to use WinISO. It will open BIN files without the corresponding CUE file. There are a few programs out there that will do this. Save yourself the hastle and get one of them
    Impossible to see the future is. The Dark Side clouds everything...
