Hi,
I have ripped Xmen 1.5 and want to copy the movie only.
When I open up DVD2ONE there are 3 title sets each of the same length and number of chapters.
Are they all the same ?
Which one is the best to opt for ?
Cheers.
dlb.
If you have it set to movie only setting, then pick the one with most chapters and the longest time. When you play the movie, it immediately starts from the beginning without the previews and less the menus. The rest of the selections are just bonus material and menus. Its pretty simple so you should get it.
BBoySoldier -
wow did u read anything he wrote in his post???? he said they all the same length and have the same amount of chaptersOriginally Posted by bboysoldier
I don't know about XMEN 1.5 but I know the original XMEN was a seamless branching type. I also know that other movies such as Independence Day and Beauty and the Beast have title sets which are the same, exact size. The reason for this is because there are versions which were amended or are NOT part of the theatrical release. I believe the extended, seamless branching title of the original XMEN had an XMEN symbol EVERY TIME a part occurred which wasn't in the original movie.
I am not into that...and just wanted the original PGC...so that is what I ripped. In your case...you will need to do the same. Just check the .IFO file in IFOEdit...or do a search on this site to try and find out which of the three PGC is the original...or the one you want to keep. You can also keep all three...but that gets tricky, and isn't worth it in my opinion. -
the seamless branching (which isn't seamless, go figure) in xmen was irritating, but easily solved. pop the disc in your DVD player, press "play movie" and note the title number. that's the one you want in DVDdecrypter. other method is to check your inlay for the number of chapters in the film and pick the PGC with that many chapters. from what i remember it wasn;t the longest, or second longest, it was third longest.
Blu-Ray Rip of Movie Xmen First Class !
By augustya in forum Blu-ray RippingReplies: 3Last Post: 22nd Feb 2012, 12:18 -
60gb Avi file - To DVD - Puzzled
By andrewmpalmer2003 in forum Video ConversionReplies: 6Last Post: 1st Apr 2010, 08:56 -
DivX v/s Xvid trial and error now puzzled, read toward end
By adiktlost in forum Newbie / General discussionsReplies: 7Last Post: 12th Jan 2009, 20:37
