On several DivX moives, when I try to encode them to VCD format using TMPGENC, I get an error that reads "An error occured when audio is decoded"
I assume I could correct the error by separating the video and audio, and also assume I should be able to do this in VitualDub. But, I can't seem to figure how to do this. Could someone please explain, or tell me a different way to fix this problem.
it tells you how to separate the audio with virtual dub, if you click on convert with TMPGEnc and go down to the bottom. There is a problems section, click on the one that says something about the audio being bad, and it'll tell you how to use virtual dub. NOTE: you have to get the virtualdub 1.3 version, not a 1.4 version, and you have to get the smr codec also.
jason
Staxrip error converting MKV/264 to DivX HD
By jwjr417 in forum Video ConversionReplies: 7Last Post: 18th Apr 2010, 10:00 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
Converting HD (DivX/MOV/WMV etc) to DVD or DivX ???
By snadge in forum Video ConversionReplies: 32Last Post: 8th Jan 2008, 06:48 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54
