I've got a couple of downloaded clips in ASF format that I've had trouble converting. I've since found that the problem files are using the Microsoft MPEG-4 video codec, and the Windows Media 8 audio codec.
In TMPGENC these clips take over an hour to convert a 4min vid. The resulting MPG video plays fine, but only the first couple of seconds of audio then silence.
Anyone any ideas?
Thanks,
NiVZ.
Not a real good solution, but could you open them up in VDub and save as Uncompressed AVI (huge as hell, but for only 4 mins, itll be alright), then open up THAT file from TMPEG?
Originally Posted by phatslug
Thanks I will give it a try this coming week.RXH -
Turns out it's the Audio thats the problem.
I converted the Audio using Windows Media Encoder 9 and then used the video from the original file in the Video option, but used the converted audio from WME 9 in the Audio option of TMPGEnc.
Works fine now.
NiVZ. -
try VideoEdit Converter Pro that support mpeg4 to mpeg1,mpeg2,vcd...
http://www.viscomsoft.com/videoeditconvertpro.htm
Fixing an MPG4 file
By Linz1607 in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 10:45 -
MPG4 File Repair
By RickGaspar in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2010, 11:14 -
Help with brief video freezes in mpg4 avi
By hibbs in forum Newbie / General discussionsReplies: 5Last Post: 28th Apr 2010, 18:04 -
FLV format conversion to MPG4
By Simon5005 in forum Newbie / General discussionsReplies: 1Last Post: 27th Jul 2008, 10:09 -
MPG2 or MPG4???
By JennyBear in forum Newbie / General discussionsReplies: 7Last Post: 1st Aug 2007, 17:33
