hi
i have a very strange problem
i have winxp
i open svcd2dvdmpeg and i get the following error
application has generated an exception could not be handled
process id=0xd90 (3472), Thread id=0xccc (3276)
btw has anyone used the (+)version of this program and found it to have this same problem
AnonymousGuest
Are you just starting the program from the start menu?
AnonymousGuest
hey strange now it works
i guess i had a virus before
cuz a lot of my programs were acting strange
i installed norton and did a virus check and now svcd2dvdmpg opens up -
AnonymousGuest
Hi there,
I have the exact same problem here and i am running the same operating system, i get the problem when i click the icon in updated cache, when i start it from the start menu i get installing the program and when it finishes installing i get the home page where i donated the money to have this program , it was running no problems but something went wrong with my operating system and had to restore my operating system with ghost and obviously the program was not installed when i done my backup with ghost, any ideas to what is happening here as nothing has changed since the first time i installed it any help would be appreciated
thanks
rab -
Try this (from my FAQ):
Why does Windows Installer keep starting when I try to run SVCD2DVDMPG+?
Whilst I have never been able to replicate this problem on any of my systems, a few people have had this issue. I have written a small fix:
http://www2.svcd2dvdmpg.com/RemoveMSI.exe - you need to save it first before you run it.
It removes Windows Installer settings for SVCD2DVDMPG+. It will render useless the shortcut you currently have but you can delete that & create another. Alternatively you should be able to start the app from the program folder. So depending on where you are in your cycle:
Install SVCD2DVDMPG+
Run removemsi.exe
Run SVCD2DVDMPG+. (as its the first time it will update itself)
Sort out shortcut.
You should have no more problems now.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Opening Avisynth script on virtualDub - Error Message
By HugoBraule in forum Newbie / General discussionsReplies: 2Last Post: 25th Apr 2010, 21:48 -
After Effects error: opening sound component (-2166)
By santolina in forum EditingReplies: 0Last Post: 24th Apr 2010, 08:36 -
error when opening up mkv file with virtualdubmod
By parth82390 in forum Video ConversionReplies: 5Last Post: 5th Dec 2007, 18:00 -
Error message popup when opening folders with vids
By majax79 in forum ComputerReplies: 32Last Post: 26th Sep 2007, 02:31 -
Error when opening avs in VirtualDubMod
By chrishallowell in forum Newbie / General discussionsReplies: 6Last Post: 28th Aug 2007, 07:57
